Universal Joint Lub
put the truck on jacks and spin the shafts, that should expose the zerk/zirk (don't know how its spelt) fittings.
...or just roll the truck a little bit so the fittings are exposed and easy to get to. I have never had a problem getting to them when they are rotated to the proper position.
I have one zerk like that on the front end of the rear DS. You can't get a coupler to slip on the zerk do to lack of spacing. Turn the shaft anyway you want to and it's a no go. All most like it's a smaller u-j but it isn't. I have been searching for a smaller dia. coupler to use but haven't found one yet. Also on the cardan joint I had to drill a bigger hole through the tranny support to get to the flush (inverted) zerk on that with a neddle adapter. You can get to the front half of the joint but not the rear half. A mfg goof I believe.
