:help: Still need help Fuel pump sending unit in my 89 Comanche :headpop:
Ok now that the weather has warm up a little (16F)I've taken the fuel pump out of the tank.
I checked the relay and it clicks. I checked the fues link and thats ok. I checked under the truck and were the harness connects to the fuel pump there is power only to the red wire.
I believe the red or orange is the hot and the black should be the ground. I have a test light and had a pal turn on the key and I only get a light from the red to a ground, on the transfer case. Then when I connect to the black ground and the red while someone turns the key I get nothing, no light. Any ideas out there? Is there another test or a pressure switch?
I replaced my bed with a wooden bed would this be any reason I don't have a ground?
I have two pumps both used. When I connected to the battery I get a low noise on one and on the other I get a loud noise. Thats connecting the red to the pos post and the black to the -neg. So this says the louder one is the good pump.
there are a total of 3 wires the other wire is for the float and that works. When I connect to the + pos battery to the red and the -neg to the green or blue the light is on and if I move the float up the light dims and then out.
Sounds like you have a open ground wire at the fuel pump connector. Do you have a multimeter? Check for continuity between your black ground wire and a good ground point on the frame.
