jeepcoma Posted January 2, 2009 Posted January 2, 2009 Took my MJ in for inspection today and failed safety for a few things :(. I need new ball joints for the front, both upper and lower for both sides. I saw the tech looking up the parts on his computer and he listed part numbers from the NAPA site, Upper ball joint 2601291 and lower ball joint 2601292. I'm trying to find some cross reference lists but no luck. Are the MOOG part numbers K3134T and K3161T respectively? There are a bazillion part numbers out there for many different brands, I just want to make sure that I order the correct parts. Napa and Autozone both have two version (cheap and premium), plus several aftermarket companies. I've done some searching and Moog seems to be held in high regard, but I'm on a tight budget right now and this is an unexpected cost to deal with, so I'm trying to shop around for a good price. Thanks in advance
SuperWade2 Posted January 2, 2009 Posted January 2, 2009 Took my MJ in for inspection today and failed safety for a few things :(. I need new ball joints for the front, both upper and lower for both sides. I saw the tech looking up the parts on his computer and he listed part numbers from the NAPA site,Upper ball joint 2601291 and lower ball joint 2601292. I'm trying to find some cross reference lists but no luck. Are the MOOG part numbers K3134T and K3161T respectively? There are a bazillion part numbers out there for many different brands, I just want to make sure that I order the correct parts. Napa and Autozone both have two version (cheap and premium), plus several aftermarket companies. I've done some searching and Moog seems to be held in high regard, but I'm on a tight budget right now and this is an unexpected cost to deal with, so I'm trying to shop around for a good price. Thanks in advance This is what I put on mine (and ordered from Amazon.com (although they were cheaper when I got mine a year ago... Moog Chassis K3134T Upper Ball Joint $43.20/ea http://www.amazon.com/gp/product/B000C542NY Moog Chassis K3137T Lower Ball Joint $46.69/ea http://www.amazon.com/gp/product/B000C57XHQ
BLHTAZ Posted January 2, 2009 Posted January 2, 2009 I understand the budget thing very well, but there are some things (ball joints being one) that you cannot take a chance on with something "cheap". If a ball joint breaks...it could kill someone. Search for hte best price, but stick with either parts from the dealership or MOOG in my opinion. :cheers:
maddzz1 Posted January 3, 2009 Posted January 3, 2009 I believe the 3161 is for 1990 and up. The #'s that SW2 gave I believe are the correct ones. I have a set at home waiting to go in.
SuperWade2 Posted January 3, 2009 Posted January 3, 2009 I believe the 3161 is for 1990 and up. The #'s that SW2 gave I believe are the correct ones. I have a set at home waiting to go in. They seemed to work on my 89 SW2
