Doors from a Cherokee Classic..
As long as it's a 4 door, they will. It's not actually fabrication that's needed for the latches either. I believe it's just unscrewing the cab side piece from the donor, and screwing it higher up on your MJ.
What about the door panels? Can to old ones be reused, or do you need to use the new ones? If so, is there a problem with them integrating with the old dash?
