has anyone cut out the cat and put the muffler right after the header and brought the pipe straight out the side? I'm thinking of doing it tomarow and wanted to know if it did any thing. or if any one had some pics of what it would look like
Not quite, but close. My truck didn't have a cat when I bought it. The rest of the exhaust was swiss cheese. So after I bought a new front pipe I put the stock muffler (only good piece of exhaust I had) directly after the front pipe where the cat is supposed to be. Then I followed that with a 30" glass pack to make it to the next exhaust hanger, and a downturn that dumps in front of the rear axle.
Be aware that in a lot of areas, if you dump out the side it has to be behind the cab to be legal. Or at least behind the rear most seat, which in our case is behind the cab.
yep i did it new down pipe cut off flange thrush charry bomb 90 up 90 rt straite pipe out thru rear fender in front of tire behind door
ps 90 up 90 rt runns u between unirail and bottum of bed so nothing below frame no pic to cold out right now and yes it is load and yes i like it :cheers:
No offense, but that is one serious hackjob :nuts:
Why didn't you just go under the fender instead of ruining it? :huh???:
its not done just tep. but that will be were it exits nothing below the frame rail
it will be finished in the spring when i can work outside it will have a crome tip and stainless steel ring around it
:fool:
if i go below the fender it will be blowing on rails when installed all high and tight it sees more off road than on
