watchamakalit Posted December 18, 2008 Share Posted December 18, 2008 Anybody ever swap in a TF904? I know alot of people want an auto in there trucks but don't want to deal with the hassle and work involved in an aw4 swap so why not the 904? Am I missing something other than the fact that it won't have an overdrive? I belive one out of a early 90's YJ should swap right in behind the 4.0l and still allow use of the 231 correct? Link to comment Share on other sites More sharing options...
Geonovast Posted December 18, 2008 Share Posted December 18, 2008 Wasn't the 904 used behind the 2.8 and early 2.5? Beside it not bolting up, I'd think a 4.0 would grenade it, even if you got it in there. The AW4 is a much stronger tranny. Link to comment Share on other sites More sharing options...
reson46 Posted December 18, 2008 Share Posted December 18, 2008 I know alot of people want an auto in there trucks but don't want to deal with the hassle and work involved in an aw4 swap so why not the 904? What's the hassle in swapping an AW4? :hmm: It is almost completely self contained with its own computer and only needs input from the TPS. Get all the wiring and computer from the donor truck and it is probably about the easiest swap possible. Willy Link to comment Share on other sites More sharing options...
watchamakalit Posted December 18, 2008 Author Share Posted December 18, 2008 The 904 is stout as hell I have one in my CJ and it has put up with tons of abuse from a built 4.2L. And they used the 904 in the early YJ's behind the 4.0 with a 231 behind them. I am not arguing the AW4 is stronger but the 904 is no wimp. I thought you had to swap the entire underhood harness to do the AW4 swap? :???: Link to comment Share on other sites More sharing options...
reson46 Posted December 18, 2008 Share Posted December 18, 2008 I thought you had to swap the entire underhood harness to do the AW4 swap? :???: All you need are the two harnesses for the transmission. Nothing needs to be done to the engine wiring besides swapping out the TPS. Willy Link to comment Share on other sites More sharing options...
watchamakalit Posted December 18, 2008 Author Share Posted December 18, 2008 Hmmmmmm looks like I might make a trip to the junkyard.... Link to comment Share on other sites More sharing options...
