ricksjeepster Posted December 16, 2008 Share Posted December 16, 2008 My truck started to show a new issue when i stop in a red light does one of the next things: Sometimes it accelerates like hell with no aparent cause... and sometimes the engine begins to die almost to completely death point, but if i step hard on the brake it gets better. my first thought was that it could be a problem with the booster but I'm no mecanic genie so i want to ask you guys who probably know better Its really weird and gets me all... :wall: Rick Link to comment Share on other sites More sharing options...
MJ300 Posted December 16, 2008 Share Posted December 16, 2008 TPS?? :dunno: Link to comment Share on other sites More sharing options...
Throttle_Jockey Posted December 16, 2008 Share Posted December 16, 2008 If you have the 4.0 renix version I would say start with checking the intake manifold for leaks,but the high idle problem could also be caused by the idle air control (IAC) bhltaz had a really good thread on a simular problem also. Link to comment Share on other sites More sharing options...
jtdesigns Posted December 16, 2008 Share Posted December 16, 2008 IAC.. You should at least take it out and clean it real good. Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 16, 2008 Share Posted December 16, 2008 IAC.. You should at least take it out and clean it real good. :agree: Take the IAC out and clean it and the throttle body real well. The "stepping on the brake" things has me thinking that there may be a vacuum leak issue somewhere though too...possibly in the booster. Link to comment Share on other sites More sharing options...
jtdesigns Posted December 16, 2008 Share Posted December 16, 2008 IAC.. You should at least take it out and clean it real good. :agree: Take the IAC out and clean it and the throttle body real well. The "stepping on the brake" things has me thinking that there may be a vacuum leak issue somewhere though too...possibly in the booster. Thats what had me thinking it was the IAC. It basically is a controlled vacuum leak.. If it was a regular vac leak it would have a fast idle all the time. If its (IAC) is stuck shut, the loss in vac when you step on the brake will cause a higher idle.Even in a correctly working system youll get a change of idle when the brake peddle is depressed.. If the booster is leaking it would be just like any other vac leak and keep the idle high at all times. I could be wrong but thats how I see it. Link to comment Share on other sites More sharing options...
ricksjeepster Posted December 16, 2008 Author Share Posted December 16, 2008 Thanks guys I`ll be checking on the IAC for dirt or something, this is a good point to start discarding causes of problems in the truck Thanks again guys!!!! ps i`ll check for vaccum leaks also.. :thumbsup: Link to comment Share on other sites More sharing options...
