xj_dummy Posted December 9, 2008 Share Posted December 9, 2008 On my 86 2.5L Comanche? I bought a set for my 90 Xj and never installed them, and I don't want to go and exchange them if I don't have to. Thank you for ANY help. Link to comment Share on other sites More sharing options...
james750 Posted December 9, 2008 Share Posted December 9, 2008 Some of the 90's use composite rotors that will not work on older MJ's, the 86 was kind of a strange year for the MJ as was the 84-86 XJs; not sure but the brake system could be completely different on your Mj than the 87-90s. Link to comment Share on other sites More sharing options...
Eagle Posted December 9, 2008 Share Posted December 9, 2008 1990 was the first year for the second generation of the XJ/MJ front brake system. The knuckles, rotors and calipers are ALL different from previous years, IIRC. I don't know if the pads might be the same, but if the calipers are different I rather doubt it. Here's the Cliff's Notes capsule summary of what fits: · Only two steering knuckle designs were used: 1984 through 1989, and 1990 through 2001. Left and right side knuckles are different part numbers within each group. · Three different hub/bearing units were used. The hub/bearing units are the same for both sides of the vehicle. The different years for hub/bearing assemblies were: 1984 through 1989; 1990 through mid-1999 (composite rotors); and late-1999 through 2001 (cast rotors). · Three rotor types were used: 1984 through 1989; 1990 through mid-1999 (composite); and late-1999 through 2001 (cast). · Only two caliper types were used: 1984 through 1989, and 1990 through 2001. Left and right side calipers are different part numbers within each group. The above is copyrighted and may NOT be reproduced or distributed. You may print out one copy for your own, personal use. Link to comment Share on other sites More sharing options...
