As some of you know I am in the middle of doing a 4.0L swap into my MJ. For sake of ease for now it will be 2wd(for now) How long are your 2wd drive shafts?
Not sure... I guess I can go to the garage and measure it...after I pull it down from the attic part :roll: Unless you are putting in a SYE it should work for you. I can tell you a SYE, LOng bed, with SOA,equals a 52.5" shaft
