BLHTAZ Posted December 7, 2008 Posted December 7, 2008 You will be hard pressed to find any OEM liners left that are in decent shape. There are bedliners out there, just not likely to be "OEM". Spray liner (Line-X, Rhino etc...) is the best way to go as the plastic ones do as much damage as they do good.
1999MJ Posted December 7, 2008 Posted December 7, 2008 I had 2 OEM liners with Comanche molded in them in mint shape and I couldn't even give them away. Where were you a couple weeks ago.
project88mj Posted December 7, 2008 Posted December 7, 2008 i got one like 1999mj had if you want it send me a pm
johnnyc Posted December 7, 2008 Posted December 7, 2008 Spray liner (Line-X, Rhino etc...) is the best way to go as the plastic ones do as much damage as they do good. Maybe back east. ;) I got a free bedliner from somebody a few months back. It had been in his Jeep for 20 years. When we took the bedliner out, the paint in the bed was absolutely perfect. It looked like it did when it rolled off the assembly line. :eek: I've since given the bedliner away and am going with Line-X. I just think it looks better. :D
wolfpackjeeper Posted December 8, 2008 Posted December 8, 2008 I have one I could not give away. The paint is fine under it, save for one small spot on a rail. What I do not like about it is there are no tie down points in it.
SoloCamo Posted December 8, 2008 Posted December 8, 2008 I've got what I'm assuming to be an OEM one mine. It has Comanche embedded on it near the cab and is a perfect fit.
1990 Pioneer 4x4 Posted December 8, 2008 Posted December 8, 2008 Good luck finding one in real good shape. I had an OEM liner in mine for nearly 20 years and it didn’t cause any damage other than a little surface rust developing under it. I sure like the Rhino liner I replaced it with.
