ironhead03 Posted December 5, 2008 Share Posted December 5, 2008 Just wondering if anyone was running a 231 doubler? How do you like it and what did you do for shifters? Cost? How do you get in touch with Duffy to buy one? Link to comment Share on other sites More sharing options...
A-man930 Posted December 5, 2008 Share Posted December 5, 2008 I would love to have one of these someday, except I would mate it to an AMG242 (Hummer case) 8) Link to comment Share on other sites More sharing options...
Motion Offroad Posted December 5, 2008 Share Posted December 5, 2008 I know of 2 kits currently on the market for doubling the 231. They are the Madrooster Offroad Kit and the DD Machine Box4Rocks kit. The Box4Rocks kit is defiantly a nice setup. We used it with a Dana 300 / NP231 doubler combo. Worked perfectly. The Box4Rocks kit I believe runs right at $399 (last time I checked), where the Madrooster kit is more expensive at around $100 more. As to why one is better than the other I have no clue as I've not researched them in depth. As far as getting them, here is the info I can provide for you. D.D. Machine (ask for Duffy) (360) 779-2500 dd98370@hotmail.com (I believe he has Yahoo Msg. as well under the name of djld98370) Madrooster Off Road (ask for Phil) (559) 232-5566 madroosterfab@yahoo.com or desertcj2002@yahoo.com (I believe he has AOL Msg. as well under the name of ieffed) Hope that helps! :cheers: Link to comment Share on other sites More sharing options...
reson46 Posted December 9, 2008 Share Posted December 9, 2008 Yes, we are using it. I also have a second one that will go in front of an Atlas in a Scout I am building. This is what I did with the shifters. Lots of other pics in our build thread. Willy Link to comment Share on other sites More sharing options...
ironhead03 Posted December 11, 2008 Author Share Posted December 11, 2008 Nice job on the shifters.Can you give me any more info on them? Did you make the plate that bolts to the tranny or is it something i can buy? What are the shafts off of? They really look good? Thanks. Gary Yes, we are using it. I also have a second one that will go in front of an Atlas in a Scout I am building. --->This is what I did with the shifters. Lots of other pics in our build thread<---. Willy Link to comment Share on other sites More sharing options...
reson46 Posted December 11, 2008 Share Posted December 11, 2008 Can you give me any more info on them? Did you make the plate that bolts to the tranny or is it something i can buy? It's the stock bracket that the shift linkage pivots on. I just drilled a hole in the appropriate place in the brackets and welded a bolt in for my shifters to pivot on. What are the shafts off of? The shafts that come up through the floor? They are solid rod I picked up at the hardware store and bent to the necessary shape. Also found the shift knobs at the hardware store. Willy Link to comment Share on other sites More sharing options...
ironhead03 Posted December 12, 2008 Author Share Posted December 12, 2008 Thanks Willy. Can you give me any more info on them? Did you make the plate that bolts to the tranny or is it something i can buy? It's the stock bracket that the shift linkage pivots on. I just drilled a hole in the appropriate place in the brackets and welded a bolt in for my shifters to pivot on. What are the shafts off of? The shafts that come up through the floor? They are solid rod I picked up at the hardware store and bent to the necessary shape. Also found the shift knobs at the hardware store. Willy Link to comment Share on other sites More sharing options...
