GaruMJ Posted December 5, 2008 Posted December 5, 2008 What do you think guys about install a supercharger of a 3.8 liter ford thunderbird and running 4.56 gears on a comanche ´90 I6 4.0 automatic 4x4. we use our cars for this... http://es.youtube.com/watch?v=ZI-n_vBVom8
GaruMJ Posted December 5, 2008 Author Posted December 5, 2008 some guys are running the supercharger in their XJ but with 3.55 gears :thumbsup: and I am not sure how is going to work with the 4.56 gears on my truck. :D any advise???????
DirtyComanche Posted December 5, 2008 Posted December 5, 2008 Should work. Low gears won't hurt. Try it and report back.
GaruMJ Posted December 5, 2008 Author Posted December 5, 2008 Should work. Low gears won't hurt. Try it and report back. I forgot to tell you I am running on 31´ all terrain and I don´t want to jump to a bigger tires.
SoloCamo Posted December 5, 2008 Posted December 5, 2008 As long as you do supporting mods for the S/C such as larger injectors, cooling, etc I don't see there being a problem. 4.56's with 31's isn't something I'd exactly want to daily drive, though. However, for this purpose it would probably be great. Maybe 4.10's would be a better choice though so you aren't shifting gears as much while climbing and will keep you in the power band longer.
BLHTAZ Posted December 5, 2008 Posted December 5, 2008 Supercharged with 4.56's & 31's will go about 50 MPH in 4th gear at 5-6000 RPM...not a good combination :???: . IMO - 3.73's would be the gear to go with for that set-up...if, as you say, you are not going to go bigger.
GaruMJ Posted December 6, 2008 Author Posted December 6, 2008 Supercharged with 4.56's & 31's will go about 50 MPH in 4th gear at 5-6000 RPM...not a good combination :???: . IMO - 3.73's would be the gear to go with for that set-up...if, as you say, you are not going to go bigger. I am running 4.56 actually with the stock motor with just magnaflow, K&N intake sistem and 2001 intake maniful, and I think it is not bad, it doesn´t go to 5000RPM maybe 2000-2500rpm or so. and that´s what I was thinking if I add a supercharger it could rev alot faster and that´s what I don´t want. and the good.....I have a 3.73 gear set as spare, front and back. :clapping:
BLHTAZ Posted December 6, 2008 Posted December 6, 2008 OK...I was exaggerating a little bit on the RPM's, but you get the point ;) :D . I run 4.56's with 35's, 4.0L, AX15 and it is plenty of gear for that. I could actually run 37" tires with the 4.56's and have no problem as they seem to be a little too much gear for the 35's.
Jacobs Posted December 6, 2008 Posted December 6, 2008 Supercharged with 4.56's & 31's will go about 50 MPH in 4th gear at 5-6000 RPM...not a good combination :???: . IMO - 3.73's would be the gear to go with for that set-up...if, as you say, you are not going to go bigger. That seems just a little off, I'm calculating more like 119mph in overdrive at 5k rpm. :???: With 4.56, auto, 31's. Of course the supercharger makes no difference in the speed per rpm.
BLHTAZ Posted December 6, 2008 Posted December 6, 2008 Supercharged with 4.56's & 31's will go about 50 MPH in 4th gear at 5-6000 RPM...not a good combination :???: . IMO - 3.73's would be the gear to go with for that set-up...if, as you say, you are not going to go bigger. That seems just a little off, I'm calculating more like 119mph in overdrive at 5k rpm. :???: With 4.56, auto, 31's. Of course the supercharger makes no difference in the speed per rpm. :yes: :yes: :thumbsup: OK...I was exaggerating a little bit on the RPM's, but you get the point . I run 4.56's with 35's, 4.0L, AX15 and it is plenty of gear for that. I could actually run 37" tires with the 4.56's and have no problem as they seem to be a little too much gear for the 35's.
Jacobs Posted December 6, 2008 Posted December 6, 2008 right- well let me know when you make up your mind, then.
DirtyComanche Posted December 6, 2008 Posted December 6, 2008 People make sure a huge deal about gears. Stop bothering. It doesn't freaking matter if it's 2200 or 2500 rpm. Which is about all the difference you'll see. But you might lose a tenth at the strip! Woohoo... Yeah... (Remember, this is my opinion, and no, I don't have any professional training in anything related to a jeep)
BLHTAZ Posted December 6, 2008 Posted December 6, 2008 right- well let me know when you make up your mind, then.Who...?? About what...??? :dunno:
