carpet
is the carpet in a mj with a bench seat the same as the carpet in a bucket seat mj ??
If the bucket truck had the mini console like the bench truck then they should be the same. If the truck had a full console there will be a cut out for the rear console mount.
ok i found one with the mini consol and I need one for the full. so it will work with out having any carpet missing ?
Should be the same. The beach seat uses the same brackets as the buckets. Just the 2 inner tracks are not attached the the seat.
