rworks Posted December 1, 2008 Share Posted December 1, 2008 OK, did a search and got the "connect tab A to slot B" instructions on how to check the TPS. Thats the easy part. I'm having some issues actually checking the voltages. Should I be stripping insulation off the wires? Poke the probes into the back side of the connector? Which works best for you guys? And is there a way to get rid of the darn TPS? The design is just poor. Last question. When I took the old TPS off the throttle body, there are two other parts that fit into the throttle body. One is a plastic gasket thing and the other is a plastic flange of some sort. The flange bit looks a little old and worn. Where can I get the part numbers for them? Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 1, 2008 Share Posted December 1, 2008 I just stuck the probes in the connector beside the wires when I checked mine. It was a little bit of a PITA, but I got it done. No...you can't do away with the TPS unfortunately. Don't have any clue what you are talking about with the plastic thing/gasket :dunno: . I didn't see anything like that on mine when removed. Link to comment Share on other sites More sharing options...
rworks Posted December 1, 2008 Author Share Posted December 1, 2008 I just stuck the probes in the connector beside the wires when I checked mine. It was a little bit of a PITA, but I got it done. No...you can't do away with the TPS unfortunately. Don't have any clue what you are talking about with the plastic thing/gasket :dunno: . I didn't see anything like that on mine when removed. The plastic bit I was talking about sits between the TPS and the throttle body. Here's a pic of it: Also, I was looking at my setup and its obvious to me now that I don't have the stock deal going. My MJ is an '87 but the engine is from a 01 Grand Cherokee. The TPS is mounted on the firewall side of the throttle body (vice the radiator side where the RENIX would be) and the throttle body appears to be a 91+. The only thing this appears to affect is the placement of the TPS and it looks to me like the little plastic bit I was talking about is jury-rigged to fit, given that the 91+ doesn't use the same TPS as the 90-. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted December 1, 2008 Share Posted December 1, 2008 http://www.greatlakesxj.com/tech/TPS.html Link to comment Share on other sites More sharing options...
