tazjeeper Posted November 27, 2008 Share Posted November 27, 2008 Ok the transfercase does work and the front driveshaft does ingage and dis ingage but the rightside axle does not on my 91XJ. I know it has something to do with the vacume. what can I cheak as it has sliped my mind after a few years of not being around jeeps. Thanks for the help. Link to comment Share on other sites More sharing options...
Pete M Posted November 27, 2008 Share Posted November 27, 2008 Your CAD (central axle disconnect) probably isn't engaging. Most guys just bypass the problematic vacuum systems and shim it to be engaged all the time (making it just like all the Jeeps that never came with a CAD). See here for how to do that: viewtopic.php?f=2&t=12795 Link to comment Share on other sites More sharing options...
tazjeeper Posted November 27, 2008 Author Share Posted November 27, 2008 Thanks. I think I understand from all that I should remove the CAD and shim the linkage over. but this will make it fulltime 4wd right, or just always turn the front axle? 2 and 4wd from tansfercase still work? do I have to block off the vaccum lines. and when you remove the Cad and shim or change the pin on it so it is ingaged do I move axel over then reinstall????? I would have to right? :dunno: :cheers: Link to comment Share on other sites More sharing options...
Pete M Posted November 28, 2008 Share Posted November 28, 2008 All it does is makes the passenger side into a one piece axleshaft, just like every other Jeep since the early 90s (XJ stopped in ~92, wrangler stopped in 95). It does not give you AWD. You t-case will still function exactly like it does now. :thumbsup: Link to comment Share on other sites More sharing options...
tazjeeper Posted November 28, 2008 Author Share Posted November 28, 2008 Thanks Pete thats what I thought. I have never hear of that mod up here and well like I said its been a few years sence I have been into jeep. :cheers: I am going to do that today and let you know how I make out. Link to comment Share on other sites More sharing options...
tazjeeper Posted December 1, 2008 Author Share Posted December 1, 2008 well I have not done this yet but the one on the mj works realy well so when i change the rear end to the xj I may just change the front if the gear ratio is different anyway. IF not then I will swap just the actuator over and see if it works on the Xj front end. Link to comment Share on other sites More sharing options...
tazjeeper Posted December 23, 2008 Author Share Posted December 23, 2008 Well thanks for all the help guys. I had a short day at work today and after getting stuck in the snow yesterday I was able to get the jeep in the garage and fix the font axle. the boys were king of looking at me strange when I started to put spacers on the fork shaft and then put it back on the front housing.. worked great and Me girl is loving me again now that we have snow all over the place. Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 24, 2008 Share Posted December 24, 2008 Glad to hear that you got it going... :thumbsup: Link to comment Share on other sites More sharing options...
tazjeeper Posted December 24, 2008 Author Share Posted December 24, 2008 Me too I had to haul a chev out of the driveway the otherday in about 1 1/2 of snow and thats no fun with 2wd....LOL Link to comment Share on other sites More sharing options...
