flint54 Posted November 21, 2008 Share Posted November 21, 2008 Yep, check engine light just came on (not the maint req'd light), only 58,000 miles, and runs perfectly. The "check it for free" place only reads OBD II. Wasn't there some scheme about clicking the key "x" times, and count long/short blinks, then go find a decipher code somewhere? Wasn't there also some pins to jumper, once the fault is corrected, to reset the light? Link to comment Share on other sites More sharing options...
BLHTAZ Posted November 21, 2008 Share Posted November 21, 2008 Key cycle... On - Off - On - Off - On and leave it. The Check Engine light will begin to flash. Flash, Flash ... short pause ... Flash, Flash, Flash, Flash = 24 ...long pause... Flash, Flash, Flash, Flash ... short pause ... Flash, Flash, Flash, Flash, Flash = 45 etc, etc... When you get a 55 = end of cycle Link to comment Share on other sites More sharing options...
flint54 Posted November 22, 2008 Author Share Posted November 22, 2008 Got it - thanks! Code = 12 and code = 22. From here: http://www.allpar.com/fix/80s-codes.html I get the following: 12 Battery or computer recently disconnected 22* Coolant sensor signal out of range - May have been disconnected to set timing I recently had some things disconnected, so likely the source. What I can't find is how to turn the light off. Link to comment Share on other sites More sharing options...
BLHTAZ Posted November 22, 2008 Share Posted November 22, 2008 If you think you have the problem fixed, just disconnect the negative terminal from the battery and leave it off for a few minutes and it should clear the code. Link to comment Share on other sites More sharing options...
flint54 Posted November 22, 2008 Author Share Posted November 22, 2008 I will give that a try, but I'm curious how disconnecting the battery will clear the code that was generated by disconnecting the battery? Link to comment Share on other sites More sharing options...
johnnyc Posted November 22, 2008 Share Posted November 22, 2008 You will always get a code 12 to signify the beginning of the sequence. And a code 55 to signify the end. So it's only the code(s) between the 12 and 55 that matter. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 22, 2008 Share Posted November 22, 2008 I will give that a try, but I'm curious how disconnecting the battery will clear the code that was generated by disconnecting the battery? The #12 code will clear after 50 key cycles if all's well. Link to comment Share on other sites More sharing options...
flint54 Posted November 23, 2008 Author Share Posted November 23, 2008 Update: I've replaced the coolant temp sensor (based on code 22), I've cycled the key at least 50 times, and I've also disconnected the battery. Still have the check engine light, and still have code 22. Any ideas? Thanks! Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 23, 2008 Share Posted November 23, 2008 Update: I've replaced the coolant temp sensor (based on code 22), I've cycled the key at least 50 times, and I've also disconnected the battery. Still have the check engine light, and still have code 22. Any ideas? Thanks! Code 22 is "Coolant sensor or Circuit". It means the ECU is not seeing the correct voltage return from the sensor. This voltage varies because the sensor varies it's resistance as the coolant heats up and cools down. Check for continuity from the sensor plug back to the ECU, and check the connector itself. Sometimes the pin contacts get bent and/or corroded causing faulty resistance readings. Cycling the key 50 times does nothing for code 22, that's to clear code 12. Link to comment Share on other sites More sharing options...
