r.j.c.omanche Posted November 17, 2008 Share Posted November 17, 2008 is there any difference to a early-mid 90's 2.5L and my '86 2.5L?? i have a chance to buy a newer engine for $100. the owner wants to keep his manifolds, distributor, and acessories and brackets. so i'm thinking i can bolt my stuff on and go? :dunno: this would get my Mj project off the ground while i do body work, and get a real game plan for it. at this point the truck is so new to me i'm not even sure what i really want the final product to be. Link to comment Share on other sites More sharing options...
Eagle Posted November 17, 2008 Share Posted November 17, 2008 The 2.5L got fuel injection in 1986, one year before the introduction of the 4.0L. Both were Renix-based systems, but the 2.5L had throttle body injection rather than multi-port. Chrysler redesigned the entire ignition/injection system for the 1991 model year, on both the 2.5L and the 4.0L. 1991 and newer 2.5L engines will have multi-port injection, they use a totally different computer and wiring setup, a different flywheel and CPS, and a different fuel pump (I think). The multi-port 2.5 engines put out quite a bit more power than the TBI versions and if you're up to doing all the work to make the upgrade, IMHO it's worthwhile. But it'll be a LOT more work than finding a 90 or earlier 2.5L and dropping it in. Oh -- he wants to keep the manifolds? Not good. I know the ports were raised in 1991 on the 4.0L and the shape of the ports was modified. I never checked, but I suspect the same is true for the 2.5L -- which would mean that you cannot bolt your manifolds on and go. Link to comment Share on other sites More sharing options...
r.j.c.omanche Posted November 17, 2008 Author Share Posted November 17, 2008 edit: so i probably cannot use that engine. dang. well, i think i am going to put a set of lifters in my motor and hope for the best. hopefully that is all my engine needs and i can start driving my truck Link to comment Share on other sites More sharing options...
Eagle Posted November 17, 2008 Share Posted November 17, 2008 You can use it, but the easiest way would be to put your old head on it. Link to comment Share on other sites More sharing options...
Pete M Posted November 17, 2008 Share Posted November 17, 2008 Or you can raid the junkyard for the parts you need. Either way, the lower block should be usable for you. :thumbsup: Link to comment Share on other sites More sharing options...
