rough idle, sounds like its missfiring
got an 88 2.5, finally got it started (the power wire going to the starter was bare at the end and shorting against the block, fixed that and she fired right up) but now its back to its original problem of rough idle and it sounds like its missfiring. when i give it full throttle it bogs down severely but if i ease into the throttle it will gain rpm's but still sound like its missing. its so bad that i can't even drive it. any ideas?
  • 1 month later...
just an update:
so i got to thinking about it and realalized that it sounded like a fuel issue. sure enough it was. i held it wide open and poured gas down the tbi and she revved up like normal, but as soon as the gas burnt off it bogged down and died again. ill be replacing the fuel pump tomorrow so ill keep this updated
