help with fuel system??
The 87 comanche sports truck was acting like it was out of gas. I changed the fuel filter and the fuel pump. That did not fix the problem. It starts but after idling for about a minute it just sputters and dies. Then it acts like it is flooded and won't start for about another 10 minutes. I get a spark from the plugs... Anyone with any ideas?
Is this a 4.0L engine or a 2.5L?
If it's 4.0L, try bypassing the ballast resistor and see if it makes any difference.
It could also be a problem with the Throttle Position Sensor (TPS). You can use this to test that... http://www.comancheclub.com/forums/view ... =9&t=12260
Here is an electrical manual if needed... http://www.comancheclub.com/forums/view ... =9&t=12734
Here is the Renix FSM as well... http://www.comancheclub.com/forums/view ... =9&t=12517
