Vacuum Line Dilemna
New to MJ, exploring under the hood, and find an "extra" vacuum line that
seems to be original build (buried deep into the large harness across firewall).
One end dangles under the washer reservoir, the other end dangles next
to the brake booster. 1992 eliminator, 4.0, 5sp, 4wd.
Thanks!
Tom
Try this:
This image shows the LH end, and has a small connector inserted:
Image Not Found
This images shows the RH end, which I lifted from below the
reservoir for the photo. The reservoir has two vacuum line
support notches, and this line occupies one of those.
Image Not Found
Tom
I agree with brent. If you look at the washer fluid resevoir one of the hoses is the same as the one you asked about and the other is different. It looks like one was replaced and they just left the old one there.
+me too
That doesn't look like one of the MJ vac hoses. All of mine were thinner and more plastic than rubber.
Mystery solved. The "extra" line is configured into the harness, and is meant for an XJ with a rear washer. It runs through a boot on the firewall (on XJ only) just outboard of the brake booster, and continues along the LH sill all the way to the back.
Tom
