BPB Posted November 7, 2008 Share Posted November 7, 2008 I know that the zj disks will bolt onto a cherokee d35 / 44. will they bolt on to a waggy 44? Link to comment Share on other sites More sharing options...
Darren Posted November 7, 2008 Share Posted November 7, 2008 no they won't. the waggy is a 6 lug and the xj/my/zj is a 5 lug Link to comment Share on other sites More sharing options...
pingpong Posted November 7, 2008 Share Posted November 7, 2008 I know that the zj disks will bolt onto a cherokee d35 / 44. will they bolt on to a waggy 44? :no: This isnt entirely true. A zj d35 setup will not bolt to non c clip d35, or a late 80's xj d44. :brows: I did the swap and it is a lil bit of work. With a lil creative thinking you might be able to get them to work on a waggy axle. Buy a retainer flange (part that bolts to the end of the housing), and set it against the backing plates for the ZJ discs. It might just be as simple as redrilling the backing plate to match the retainer. then you wil need to get a spacer cut to "take up" the spacethat the caliper has now. :smart: Link to comment Share on other sites More sharing options...
