FxRacing282 Posted October 29, 2008 Share Posted October 29, 2008 found a 88 mj for 500 with an 02 TJ axle up front (D30). its a 2wd with a 5 speed. so other than a t-case & linkage) drive shafts what do i need? i can't seem to think of anything else Link to comment Share on other sites More sharing options...
Pete M Posted October 29, 2008 Share Posted October 29, 2008 A 4wd trans that matches the spline count of the t-case would help. I'd suggest AX-15. Does the front axle match the gear ratio of the rear? Link to comment Share on other sites More sharing options...
FxRacing282 Posted October 29, 2008 Author Share Posted October 29, 2008 i sure do hope so. if not i know a guy who will give me a D35&30 so that no biggy. so a no go on keeping the tranny? Link to comment Share on other sites More sharing options...
wolfpackjeeper Posted October 29, 2008 Share Posted October 29, 2008 you would need to swap the output shaft housing to a 4wd model. Wouldn't It be the ax5 anyway? I would just find an NV3550 or an ax15 external slave. Link to comment Share on other sites More sharing options...
FxRacing282 Posted October 30, 2008 Author Share Posted October 30, 2008 alrgith well thanks for your help. my father told me no more stuff in the yard so it looks like ill have to part with something to get this and i hate to say goodbye to my toys. Link to comment Share on other sites More sharing options...
Pete M Posted October 30, 2008 Share Posted October 30, 2008 If the truck is a 2.5L, then you might be able to rebuild the 2wd AX-5 into 4wd if you can get the right parts. If the truck is a 4.0L, then it's a Peugeot transmission and is best used as a boat anchor (or give it to someone in desperate need of a 2wd trans 'cause they blew up their own Peugeot). Go find an AX-15 or NV-3500 (if you can find a 3500 in your price range) Link to comment Share on other sites More sharing options...
Eagle Posted October 30, 2008 Share Posted October 30, 2008 You didn't say if it's a 2.5L or a 4.0L. Keep in mind that the TJ front axle is a low-pinion D30, so it's okay for street and light (dirt road) 4x4 use, it's nowhere near as strong as the high-pinion D30s used in the MJs and pre-Y2K XJs. If you're looking at a lift in the future, the low pinion means you'll start encountering pinion angle problems with less lift than if the axle had a high pinion. Link to comment Share on other sites More sharing options...
FxRacing282 Posted October 30, 2008 Author Share Posted October 30, 2008 my bad, its a 4.0. when i lift id run full size axles. yes the tires will stick out but i like it that way. Link to comment Share on other sites More sharing options...
