fuel pump no start issue?
Replacing the relay would be the first thing I would check.
i and many others would diagnose before relpacing. Do check the relay simply take a relay from something else that is the same. there is a tiny diagram on the top or side of the relay. swap it and if it works then there ya go. but relays are fairly reliable so to me it sounds like a key switch problem. i, in the past, have re wired a fuel pump by wiring it to one of the "ON" slots on the fuse box, but that would be a last resort. first off i would check for power to the pump while it is one. a test light will work.
