90eliminator Posted October 22, 2008 Share Posted October 22, 2008 So I started pulling the transmission last night...but ran into a slight problem. The kick down linkage that connects to the throttle body assembly and then travels down the transmission. I removed the 10mm bolt and then tried to pop the linkage out. This is where the problem exists for me now. I can get the plastic up enough to see the steel cable running into the transmission, but it won't pop out or disconnect anyhow that I see. Any ideas... thanks Shawn Link to comment Share on other sites More sharing options...
project88mj Posted October 22, 2008 Share Posted October 22, 2008 cut it :D Link to comment Share on other sites More sharing options...
Wildman Posted October 23, 2008 Share Posted October 23, 2008 I assume that your talking about the TV cable (or the "kick down")??? That's mounted internally in the AW4, if you can, pull the tranny with the TV cable attached, just disconnect the cable from the throttle mount on top of the intake. Here this will give you an idea what's involved if you really want to disconnect it from the tranny. Also tells you how to "adjust" the cable after you do your swap :brows: Link to comment Share on other sites More sharing options...
1tuffmj Posted October 23, 2008 Share Posted October 23, 2008 the kick down comes off different then the throttle.the kick down slides off where the throttle can be just puled off.be careful and take ur time Link to comment Share on other sites More sharing options...
90eliminator Posted October 23, 2008 Author Share Posted October 23, 2008 Thanks i will just keep it all together on this one and the next one... Link to comment Share on other sites More sharing options...
