The transfer case was making a lot of noise.
I picked up a new (used) one cheap.
It was a bit different. Both NP231 J's but; the new one has a different hook up for the speedo (electric vs. cable) and no provision for the 4 vacuum hose fitting that is on the comanche.
So I figured that I would just swap out the parts I need.
Once apart, I found out the the only problem with old one is that the chain is stretched out and banging against the inside of the case.
So, I'm going to make a good transfer case out of the 2 of these.
What kind of oil do you put in this thing when back together and how much of it?
Also, when I get a good one, then I may try to fix the other and sell.
Is there a master link on these things like there is on other chains?
Can a link be removed? Or do I need to get a new chain?
Can you get a chain or are they cost prohibitive?
Thanks,
Mike.
They use automatic transmission fluid and it iwll take a little less than 2 qts to fill it. If you get a fluid pump and fill it when it is in the truck all you have to do is just like a differential and pump the fluid in until it starts to run back out the fill hole then put the plug in.
You can buy new chains for them. I don't know where you might get one in your area, but there is a tranny shop near me that sells them. Typically about $50 here. There us no link to remove though...you must remove the main shaft & the front output to change it, but it's not a tough job if you just pay attention to what you are doing and work slowly.
The NP231 was sold in several different configs. The renix era 231 was sold as a 21 spline input and had the stuff for the vac. disco axle. The 231 upto 1996 was sold as a 23 spline input and didn't have the vac. disco stuff. Than 1997 on it was 23 spline and even a different configuration.
If your replacing the chain, now is a good time to upgrade it to the wider/stronger chevy 231 chain. JB Conversions sell a kit with everything needed, or you can source the parts yourself. It's part number is 2032 and it's kinda salty (around $325), but if you offroad your rig it's a great upgrade to make a very heavy duty NP231.
Thanks, Man.
I'll be fixing it this weekend.
Then the son can have his truck back.
:D It's been in the driveway for 2 weeks on jack stands.
Thanks for the heads up, but; I won't be making that upgrade.
This truck doesn't get off roaded that much and when it does, it's just trails and just around the farm.
Later. . .
Need more help, folks.
Now that I have the transfer cases apart, I can't seem to get the good tight chain on.
Do I have to completely disassemble this thing?
I was hoping I could get by with just the covers, but; I get it on and it's cocked so when I straighten the housing to insert the main shaft, the chain pops off. If I try to put it on with the shaft already in, (Hard to get to), then I can't get it on.
Help!
Got it all back together and buttoned up.
Now when the son get's back from college in a week or 2, we'll put the sucker back in the truck.
Thanks for the input. . .
