MJ.rusty Posted October 8, 2008 Share Posted October 8, 2008 my windsheild cracked and removed.(was leaking before anyway) there was a bit of rust so i wired brushed it and had someone replace the windsheild. the made the leak worse and now its probably still rusting :headpop: . i used por 15'a seam sealer (cause i couldnt find a caulk that works) to seal it for now. so... I'm going to take it out and have a pro do it. but i wanted to know if i used a rust sealer like por-15 or eastwoods rust stuff to seal the rust, that they could still get a good seal on the windsheild. i heard they use a special primer and it needs to be on bare metal. any info would be awsome! Link to comment Share on other sites More sharing options...
Catatonic Comanche Posted October 8, 2008 Share Posted October 8, 2008 This was the exact causr of my floor rust...not only from rust at the seal of the windshield, but also at the seal of the rear slider. The answer is that you have to get all of the rust either sanded or converted or it will return. It cannot be sealed as rust by any amount of silicone, sealant, etc. Going to a pro was not a bad idea considering the importance of a rust-free seal around the windows. Good luck in your campaign against rust. Sometimes I feel that the Comanche Club is a secondary support website for MJ cancer (rust) victims! :beerhead: Paul Link to comment Share on other sites More sharing options...
Wildman Posted October 8, 2008 Share Posted October 8, 2008 Yes, you need a primer on the rusted/bare/repainted pinch seam for the urethane sealant to "bond" This is what your looking for.......or have the glass shop use their primer for their sealant. Link to comment Share on other sites More sharing options...
jbhill Posted October 8, 2008 Share Posted October 8, 2008 the por 15 will work just fine, its just a thick epoxy primer. Link to comment Share on other sites More sharing options...
MJ.rusty Posted October 27, 2008 Author Share Posted October 27, 2008 ok so they won't have any problem sealing the window over top of the por 15? cause i know if your going to paint over it you need to use the por 15 self etching primer. Link to comment Share on other sites More sharing options...
