xj_dummy Posted September 30, 2008 Share Posted September 30, 2008 Today I went to the pick a part and found a fog lite switch from an 89 cherokee. Got home and pulled apart the dash and found aplug for that switch. My question is if this is pre wired for fog lites, where can I find the wires for the fog lites at the front bumper? :wavey: Link to comment Share on other sites More sharing options...
mvusse Posted September 30, 2008 Share Posted September 30, 2008 Even though the dash is wired for the switch, your headlight harness is not unless your truck came with fog lights from the factory. Link to comment Share on other sites More sharing options...
tjbliley Posted September 30, 2008 Share Posted September 30, 2008 There is a long process of finding the pin out on the bulkhead plug and adding the correct wire to your harness under the hood going to the headlight harness. It takes a while but it can be done. you need to learn how to pull the pins and then find a wire from another vehicle to add to your plug. this will help make the install look more factory. The other option is to just plice the wire and run it throught the firewall. Link to comment Share on other sites More sharing options...
Lewt2007 Posted September 30, 2008 Share Posted September 30, 2008 mine did not have the factory fog lights but it has the wiring all the way up to the front of the truck the plug is right behind my grill Link to comment Share on other sites More sharing options...
jpdriver1 Posted October 1, 2008 Share Posted October 1, 2008 mine did not have the factory fog lights but it has the wiring all the way up to the front of the truck the plug is right behind my grill mine too :brows: Link to comment Share on other sites More sharing options...
xj_dummy Posted October 1, 2008 Author Share Posted October 1, 2008 Cool, thank you all for your Help. Link to comment Share on other sites More sharing options...
