DirtyComanche Posted September 15, 2008 Share Posted September 15, 2008 I'm in a bit of a pickle. I have a D60FF rear that the spindles are trashed on. I need to replace them. Solid sells weld on ones http://www.solidaxle.com/ProductCart/pc ... product=23 They are slightly expensive, but brand new and bored out already (saves me time and headaches). Otherwise I'd have to get another housing with good spindles to cut off. Which is a waste of time and annoyance. Which is all well and good, but I think they want you to use them with a D60 front hub. Well, my hubs are fine, I want to use them. It's hard for me to get front D60 parts for a reasonable price here, and don't want to use them if I don't have to. So, how many different types of D60 hubs/spindles are there? I'm searching, but I've not reached an answer yet... Link to comment Share on other sites More sharing options...
pingpong Posted September 15, 2008 Share Posted September 15, 2008 This is a question that High Honda should be able to answer or Randy's R&P could. Link to comment Share on other sites More sharing options...
LoTGoD Posted September 15, 2008 Share Posted September 15, 2008 Dirty, Call Solid and ask to talk to Matt Martin. He is the engineer there that designed all of their products. He will help you out. If you look at the picture and description, it says it is for a rear. Phone No.: 1-888.290.AXLE Link to comment Share on other sites More sharing options...
DirtyComanche Posted September 16, 2008 Author Share Posted September 16, 2008 And the answer is, a front 60 or 14B hub... Blah. Wonder if I can get some 14B hubs? Link to comment Share on other sites More sharing options...
