CEThomas Posted September 8, 2008 Share Posted September 8, 2008 What is the max angle on the rear DS that is working for everyone. The DS vibes we have on the 7.5” lift between 50-60 is just too much. Want to see if we can work out something prior to spending the big $$$ on a SYE and Tom Woods DS Link to comment Share on other sites More sharing options...
Pete M Posted September 8, 2008 Share Posted September 8, 2008 2 questions; was the driveshaft balanced? and is it long enough? Link to comment Share on other sites More sharing options...
CEThomas Posted September 8, 2008 Author Share Posted September 8, 2008 Yes and Yes. The only time it has the vibs is between 50-60 mph and when ever the load is reduced on the drive line. Let up on the gas of speed up so you load it up and all is OK :nuts: Thought about a T-case drop kit to take some of the angle out. Link to comment Share on other sites More sharing options...
Pete M Posted September 8, 2008 Share Posted September 8, 2008 Are the angles set up properly? Meaning that the axle is pointed at the right angle? Even at 7.5", that's not a huge amount of angle for a ~45" long driveshaft. Link to comment Share on other sites More sharing options...
CEThomas Posted September 8, 2008 Author Share Posted September 8, 2008 Yes, everything was done by the book, we took a lot of time on the rear DS so we would not have a problem :roll: We have been fighting it from day one. First thought it was a bad T-case so put the backup in. Then thought it was the front DS to took it out and went for a drive and no change :roll: so thought it may have been the tork convertor so switched out the trans and tork converter with the backup trans and tork convertor and the same problem :mad: So we took the rear DS out yesterday and took it for a drive and it drove so smoth :cheers: Also if you get into it hard from a dead stop it has real bad vibs :eek: infact it's more like a pounding :eek: Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 8, 2008 Share Posted September 8, 2008 I fought this for three months after I did my lift and gear change. To make a long story short, the vibes were caused by improper backlash in the rear diff. Link to comment Share on other sites More sharing options...
CEThomas Posted September 8, 2008 Author Share Posted September 8, 2008 It's a 8.8 rear, just changed the fluid in the rear when we got it. Did not check anything inside. Link to comment Share on other sites More sharing options...
