JeepcoMJ Posted December 20, 2019 Author Share Posted December 20, 2019 Early to mid 90s dodge Dakota 4 cylinder 5 speed ax15 bellhousing. had to cut out drivers side for starter hump then weld in a piece to make up the difference. used the canary clutch, flywheel, pressure plate with the Dakota throw out plate and bearing. Shaved the pivot ball housing down 3/8”-5/8” and clearances the back of the throw out plate the same. used external slave ax15 xj master and slave from a 93-96, shortened push rod as necessary to release the clutch. That required a H.O. Pedal assembly swap and I did a dual diaphragm brake booster out of the donor for the pedal assembly. Link to comment Share on other sites More sharing options...
Pete M Posted June 7, 2020 Share Posted June 7, 2020 more tech on the subject: Link to comment Share on other sites More sharing options...
