starter motor
ok finishing up putting my mj back together but got a question on the starter motor the pos. form the battery goes to the starter on the one post and the 4 ga. wire that comes form up by the coil goes to the same post right?
thanks
The main cable from the Positive side of the battery goes to the larger post on the starter solenoid, and the smaller gauge wire(solenoid feed wire) goes to the small post on the solenoid (from the starter relay - near the coil)
