XJ problem
I had my fuel pump go out on me a couple weekends ago while I was on the road working...luckly enough my aunt lived near by..I got a new pump and replaced it..didnt replace the filter till today couse I have had problems starting it...
well.I go to my plenum and press in my pressure releaf valve and no gas comes out..WTF :headpop:
PLEASE HELP!!!
air in the lines maybe? clogged line maybe? what the hell do I do?
did you hook the pump up right? pull the filter and turn the key on to see if gas is coming out? Check fuel pump relay also.
I drove it for 2 more weeks with no problem...it just started acting up lastweek..
where is the relay..
I can hear the pump turning on...
