gconcilio Posted June 2, 2006 Share Posted June 2, 2006 I have an 88 comanche that is leaking water into the cab behind the seat on the driver side. I have used seam sealer on the seam on the lower left of the rear window. This did not work. A glass shop says the rear window is not leaking. Where else can I look? Link to comment Share on other sites More sharing options...
Bounty Hunter Posted June 2, 2006 Share Posted June 2, 2006 Door gasket? :chillin: Link to comment Share on other sites More sharing options...
JeeppinTom Posted June 2, 2006 Share Posted June 2, 2006 get the water hose out, and get someone in the cab. Link to comment Share on other sites More sharing options...
pingpong Posted June 2, 2006 Share Posted June 2, 2006 Doior gasket, top of rear window, or you could be like pong and the rain gutter is slightly pulled from the top of the cab. Link to comment Share on other sites More sharing options...
