mvusse Posted July 27, 2008 Share Posted July 27, 2008 I have an 87 Comanche with bucket seats. Between the brackets under my seats and brackets under 84-96 Cherokee power seats, will I be able to make the latter fit without major modifications, or would I have to fabricate something to make them work? Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted July 27, 2008 Share Posted July 27, 2008 The brackets from the XJ power seats will not work without modification. I have a set and tested them and they don't line up at all with the MJ bolts. Link to comment Share on other sites More sharing options...
mvusse Posted July 27, 2008 Author Share Posted July 27, 2008 Will the lower brackets (between the slider and the floor) of an MJ bucket fit on an XJ bucket? Link to comment Share on other sites More sharing options...
maddzz1 Posted July 27, 2008 Share Posted July 27, 2008 I'm pretty sure that the part that actually sits on the floor is the same or atleast very similar in MJ buckets and bench. There is a writhe up in the DIY section on how to switch it over to the XJ seats. Link to comment Share on other sites More sharing options...
mvusse Posted July 27, 2008 Author Share Posted July 27, 2008 I have seen write-ups, where you fit the XJ seat part of the slider into the MJ bracket side of the slider. However, these are XJ power seats. The slider part is not anywhere near alike. If there's a write up somewhere on making XJ power seats fit in an MJ, my apologies. Link to comment Share on other sites More sharing options...
mvusse Posted July 27, 2008 Author Share Posted July 27, 2008 Never mind. I found this picture in one of Pete's post. Looks like it's not going to work: Link to comment Share on other sites More sharing options...
mfpdm Posted July 27, 2008 Share Posted July 27, 2008 Never mind. I found this picture in one of Pete's post. Looks like it's not going to work: Oh come on. Don't give up that easy. It can work you just have to figure it out. When you do, make a write up in the DIY section. :D :cheers: Link to comment Share on other sites More sharing options...
