i found a new set of Brake disc fitting only? 84/85 modells
My Q:
are there differences between the 2 wd 84/85 Jeep Cherokee 2WD Bj. 84-85 T5108 and the 89 Modells?
or will these discs fit my 89 Axle to?
The descripzion of the sellers says Jeep Cherokee 2WD Bj. 84-85 T5108
My MJ 89 with original 2 wd front Axle
2WD's rotors house the inner/outer axle bearings, and mount on the 2WD spindle. 4WD ones don't....they just slip on the unit bearing, thru the wheel studs. Ya can't use 2WD rotors on a 4WD :(
Jeff
Hmmm. I'm hardly an expert on this but I don't ever remember hearing of a difference between 84 and 89. Jim seems to know stuff like this, hopefully he'll see this. How much of a smoking deal are you getting? If it's cheap enough, it might be something I would consider buying and if it doesn't work out, re-sell them.
Jeep on!
--Pete
usually 1 disc is like 80/120 € over here, if you will find them at all
and i did find them for 45 € a piece,
fact is the seller is getting rid of all the " old junk " thats why hes making such a good price
i think i´ll buy them an if they don´t fit sell them at ebay :-))
Whoops, sorry Barny...I misread your question :oops:
As far as I know, the 2WD beam axle is the same. I've got one sitting in the garage leftover from my conversion, and there's a '99 XJ down @ the junkyard that's 2WD. If you want, I can eyeball both of them and let you know if they are the same (?)
Jeff
@ mjeff87
no problem 8)
if you would really go, I would really apreciate this
just check if the part, "holding the disc" is different
thanks in advance
Barny,
I checked both my '87 and that '99 2WD axle in the junkyard yesterday. The spindles are the same, as far as I can tell. Also, Advance Auto lists the same part # for the 2WD front rotor for all model years. I'm pretty sure there's no difference between years, XJ or MJ.
HTH,
Jeff
Thank´s alot for the info :D
so i´ll buy the disks and see if it will be the same in my case
don´t get me wrong , i belive you, but sometime sh.. happens
As in my case with the tranny
