possum Posted July 18, 2008 Share Posted July 18, 2008 How do you do it? Do you have to remove the fender? I tried to remove the metal cap thingy on the top of it but that does not help. :huh???: Link to comment Share on other sites More sharing options...
MiNi Beast Posted July 18, 2008 Share Posted July 18, 2008 pull the inner fender skirt and you should be able to reach up the fender to the bottom side of the attenna which should have a lock nut on it holding it place. Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 18, 2008 Share Posted July 18, 2008 How do you do it? Do you have to remove the fender? I tried to remove the metal cap thingy on the top of it but that does not help. :huh???: Remove the mast #2, then unscrew the nut #3 and it will drop into the fender. To get it out you do have to open up the fender splash shield. Image Not Found Link to comment Share on other sites More sharing options...
possum Posted July 18, 2008 Author Share Posted July 18, 2008 Thanks Guys. :chillin: Link to comment Share on other sites More sharing options...
