Its slightly different for different trannys..
The ax5/15 just unbolt form the top when you remove the boot you will see. Its been a while since I looked at a BA10.....
CW
the other way is to press down on the retainer that hold the stick shift in place and twist in the counter clock wise direction it may be a bit slippery but it works and the you should be able to lift it out and remove the tranny once it has been cleared jamminz.gif
