XJs4Ever Posted July 10, 2008 Posted July 10, 2008 it does smooth out eventually but thats still wrong. I am going to replace the O2 sensor cuz it appears to be OEM and the plugs/wires/cap/rotor are new. The MAP sensor is hooked up and the vacuum lines intact but I unplugged the O2 sensor from my 89 XJ once and it pretty much did nothing so I am guessing I have something else going on. Maybe the ECM or one of the dozen other sensors but I could use some input on this one. Thanks in advance. Rick in CO
Eagle Posted July 10, 2008 Posted July 10, 2008 The O2 sensor does nothing during warm-up. On initial start-up the Renix system runs in "open loop mode," which basically ignores sensor input and uses a rich-bias, pre-mapped air-fuel curve. I'm pretty sure the O2 sensor is one of the sensors that gets bypassed because, in my '88 Cherokee, on cold mornings I can feel a stumble followed by a jump at the point when it seems to be about the right temperature to be switching into "closed loop mode."
HOrnbrod Posted July 10, 2008 Posted July 10, 2008 The O2 sensor does nothing during warm-up. On initial start-up the Renix system runs in "open loop mode," which basically ignores sensor input and uses a rich-bias, pre-mapped air-fuel curve. I'm pretty sure the O2 sensor is one of the sensors that gets bypassed because, in my '88 Cherokee, on cold mornings I can feel a stumble followed by a jump at the point when it seems to be about the right temperature to be switching into "closed loop mode." That's why I like having an A/F meter installed. Even an el-cheapo narrow band does a good job of monitoring the open-to-closed loop shift, and lets you know how the O2 sensor is performing. Well worth having IMHO. :cheers:
