woody62 Posted June 28, 2008 Share Posted June 28, 2008 I have the mirrors (big ones) on my 86 and the door hinges are junk. I guess because of the weight. I was looking at a spare door I have from a 89 and it looks like it will fit fine. How do I fix the hinges? Can I replace pins?? Will I need a different door striker? Thoughts? Ideas? Thanks, woody62 Link to comment Share on other sites More sharing options...
maddzz1 Posted June 28, 2008 Share Posted June 28, 2008 Did the wled crack? causing the door to sag? Link to comment Share on other sites More sharing options...
woody62 Posted July 2, 2008 Author Share Posted July 2, 2008 The weld seems ok. It looks like the pin is worn out. How do you replace pin or door?? woody Link to comment Share on other sites More sharing options...
Wildman Posted July 2, 2008 Share Posted July 2, 2008 Here......deziped just covered this - http://comancheclub.com/forums/viewtopic.php?t=10533 Link to comment Share on other sites More sharing options...
maddzz1 Posted July 6, 2008 Share Posted July 6, 2008 There is also a TSB that chrysler put out and you can buy a kit to fix it at the dealership. I think the kit and TSB were put out for newer XJ's but it works on Mj's. Link to comment Share on other sites More sharing options...
Wildman Posted July 6, 2008 Share Posted July 6, 2008 There is also a TSB that chrysler put out and you can buy a kit to fix it at the dealership. I think the kit and TSB were put out for newer XJ's but it works on Mj's. Yes there is a TSB and here it is- http://www.lunghd.com/Downloads_and_Lin ... rly_XJ.pdf And also the repair for the hinge pin- http://www.lunghd.com/Tech_Articles/Body/Hinges.htm Link to comment Share on other sites More sharing options...
woody62 Posted July 7, 2008 Author Share Posted July 7, 2008 Awesome guys!! Thanks. Looks like I have some work to do. I'll see what the dealer says. I think all I need now is the pins. woody Link to comment Share on other sites More sharing options...
