i have a 89 pioneer 2wd which i am in the process of gathering all parts to convert it to 4x4.
i think the tranny is a ax-15 with the 2wd piece attached.
instead of switching the entire tranny assembly for the ax-15/np231 setup i have (my ttanny has less miles and a new clutch) can't the transfercase just bolt up to my tranny now?
nice :D
mines an 89, i paid $2000(CND)
2wd, SWB, 179,000km,
i only have surface rust spots on mine
planning a 4x4 conversion with SOA (5.5 inches of lifti think)
can't wait to see you finished product :cheers:
i already have the 31's on my truck....i just want to get some more space in between the front fender and tire (less than 2 1/2")
ill keep looking around for what i want i guess....maybe just leave this for my project truck and finance a new mini...hahha
well 3.5" sounds perfect i think.
well ive decided to go against my dad and use the add-a-leaf.
anybody use the tuff country kit?
http://www.4x4wire.com/jeep/projects/co ... uspension/
i found a donor MJ for my project :D
and ill probably just sell the axles i bought. only paid $25 for them both...
i personally wanted 3-4" of lift with 31"s and to convert to 4x4. my dad refuses to use the add-a-leaf lift because he hates it (to stiff). if i do the axle over with the dana 35 how much lift than? and would a need a long arm kit? I really don't want 6".
Thats it with the 31/10.50's
k ill start over haha.
I bought 2 axles (front and back) from a 96 cherokee. I'm putting them in my truck to convert it to 4x4. after lifting the rear however much it will be after putting the 8 .25 in, than want to even out the front so its about the same.
how would i go about doing this?
i think your right :cheers: thanks to all for the help :bowdown: 8)
and i have the same axle except its the front......just longer springs and shocks to make it work? I'm converting to 4WD....sick of getting stuck on flat ground......stupid albera weather :roll:
does it make a difference that my truck is 2WD? and also if i put the 8 .25 in the leaf springs are already on top of the axle.....which would lift the read 3".....right?
