halnelmar
Everything posted by halnelmar
  1. does anyone know the axle ratio for this truck? cannot find the info for the v6 anywhere
  2. does anyone know if cherokee 4-door front tube doors will fit a comanche?
  3. ok guys, need some help (bet you never heard that one before) on my ignition. i have a new to me 1988 manche, 4.0, 5 speed, tilt column. i have read umpteen posts on this and still not sure where to start. i have a cast on my left hand up to my elbow so i would like to know opinions on most likely things to check because its hard to get under the dash with only one hand. i was doing alot of bouncing around on trails looking at some mountain property and stopped to hike a bit. when i went to leave i turned the key and nothing. turned the key again and nothing. turned key the third time and it stuck in the on position and no crank. had power to everything but now can't turn key off. finally had to take a screwdriver to the starter solenoid and it fired right up and i drove it 3 hours home. got home and key still won't turn off. tried messing with tilt, steering, and hammer tap to key and messing with the lock lever. finally put it in gear and let the clutch out to kill it. opinions? :dunno:
  4. whats strange is i bought a 88 xj last year and when i raised the hatch i noticed one of the tail lights must have been replaced because written on the exposed side is "1986 jeep comanche" written grease pencil. wth with that? so i always wondered if they would fit but i guess now i know........
  5. i might make one, and i think i will just put a layer of silicone in between them so they are glued together, then it will be a one-piece unit............ :D
  6. be sure and check behind the part you didnt remove (behind the pedals) mine was rusted there the worst......
