willys55
Everything posted by willys55
  1. When they label your vehicle as a bi-annual test vehicle...by any chance after you come back with better than the average test results do they let you return to just an annual test. I'm a NJ state inspector and we don't do the biannual so I was just wondering.
  2. Hi name is Russ I would post a photo but I'm not having any luck with this
  3. Perhaps the reason you don't see this bolt that holds the dip stick in place is because the tab on the dip stick is missing that the bolt would be holding fast. If this is the case you should be able to wiggle the dip stick tube out of the block.
