Hello my name is Jenssen, and I have a Jeep problem,...
I have a few in the stable :shake:
My Wife and I have now 4;
93 2Dr went from this:
To this (547,000KMS and still going strong)
04 TJ Rubicon
89 Cherokee
and the the Comanche,...
So here is the rusty POS that I found on Kijiji.ca when it was posted in here. I spent a whopping $50.00 to drag this cancerous demon home.
I bought this Jeep as I could justify the $50.00 as I could easily part it and recover the funds,.. now if it comes to life we can fix the rest.
So that being said this Jeep has been stolen, column smashed, been sitting for 3 years in the weeds, $60.00 later in towing the Dump Humper is home.
First things first will this bucket of bolts start and run? A battery went into the old girl,.. figured out the "hot wire" sequence and "click,...grunt" SFA happens,.. is the motor seized? Starter gone,.. I must dig deeper. Now what makes a starter engage but not allow the motor to turn over,..Seized? Well I liberally soak the cylinders with some bolt penetrating oil (why not??) and Eric my Diesel Fitter (deez-will-fit-her) asked me if I have checked the oil,.. seems simple so I did,..9 liters! So out it came and some fresh stuff went in. A fresh battery was installed , and low and behold it cranked over WHOOT! Halfway there,.. I cleaned the old plugs fixed some vacuum leaks and out came the slot blade screw driver key and a few moments later a haze of rusty black smoke reeking of stale fuel plumes from the tail pipe,. The dump humper has now moved a up status level. I changed out the injectors and installed a new column , now it starts no problem at all,.. now to face the next task,.. The Rot
,... I think I need a tetanus shot,..
