Everything posted by cord367
1986 - The Jim Oshel Edition
cord367 replied to neohic's topic in MJ Hardcore Tech: Epic Journeys to Greatness
all right Moab time, We had a good time the jeep preformed amazing plus i think my dad likes it better than his jk now. the only issue that came up was when the front locker was used the power steering would overheat which is an easy fix. for a not testing before heading out nothing bad happened or broke so ill call it a win, I got some pictures and videos too. IMG_5446.mov IMG_5433.mov- 170 replies
- 5.2l v8 swap
- long arm suspension
(and 2 more)
Tagged with:
Roughly 1 1/2 feet i think maybe a bit closer to 2.- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
the jeep moves again . it was finished a week or two ago but I've been have power steering issues but they are resolved now. so for a recap JIM now has dana 44s font and rear from a jk 5:13 gearing both with lockers. the front suspension is the same, i got a bumper from cavfab and a winch from carbon winches. the rear is 4 linked using iron man 4 link brackets, Barnes 4wd parts, and 2/5 inch tj springs. you might have also noticed the bed has also been bobbed. The steering pump is now a 2001 WJ pump with a redhead steering box. The driveshaft are the same for now. I also had to put 1.25 inch spacers on because of clearance issues in the rear. i also added some other goodies. I will get pictures of it soon because it will be finding its way to Moab next week hopefully.- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
'88 Eliminator... Feb. 2009 - Oct. 2026
cord367 replied to neohic's topic in Member Projects: Your Comanches
hell yea the eliminator is super sick and clean -
some might come back to you soon lol- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
i think I'm the fourth but idk.- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
been a sec but the jeep been at a trans shop tying to find a noise, turns out that the input bearing in the transfer case is destroyed but with that we also found where a leak was coming from. so basically when your swap a 231 in place of a 249 on a 46rh your need the swap input shafts to engage the seal which Neohic did when he swapped them. I think somewhere down the line of different owners someone swapped the transfer case and instead of swapping input shafts they made a spacer to engage the seal with in return leaks though the splines. but now that everything if figured out i got the jeep back in the garage and the transfer case is getting fixed. now the next step is getting the rear 44 in. and I've been getting side tracked with painting diff covers- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
aaaaaaaaand the front is more or less done. got new shocks and my dad got an anti rock kit. but hes once again alive and movin- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
cord367 replied to neohic's topic in Member Projects: Other Cool Stuff
looks great! -
Yea I need a frame side aftermarket one. I know all the brands and stuff I’m just seeing if the one close because it would be best to get it before Friday for me- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
alright things are goin good i am gate keeping photos for now. but me and my dad had a mess up and i am now looking for a new track bar mount. if anyone has one to spare i would appreciate it. but anyways a lot has happened pretty much i need a new track bar bracket and the front will be done i have a few other surprises that are going on as well.- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
Still got the axels only the front is out so far I do plan on linking the rear- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
after lots of writing and a competition I managed to secure a scholarship and get to keep the Comanche. My dad also surprised me with some new built dana 44s for it. Anyways everything that has been done to it so far. New dash, new radiator shroud with electric fan. Moto built a fuel cell in bed and it does work with grand Cherokee fuel pumps. That's all I got for now.- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
nope not yet a few people asking for trades/ the link got messed up i fixed it. https://www.facebook.com/share/1CbfynGpue/- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
I'm sad but i had some thing come up now i short college funds https://www.facebook.com/share/1CbfynGpue/- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
Alrighty things will be happening soon I ordered a Zj tank to replace the current tank with and fuel pump still be a bit before the trans come out. I still haven’t take Any pics but I have one. I’m hoping by November I’ll have the low ish fuel pressure and the cooling issues all sorted out to I can put my focus into some body work.(floor pan are rusted again it seems)- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
i did go that way this morning sadly didn't get on the trail today had some heat issues and might've lost a "little" coolant. do you remember seeing a white jk in front of me? i think that was the last trail run my dad has planned before winter too so i guess i gotta see how many things i can fix before spring. i also keep forgetting pictures ill try to remember to get a few tomorrow when i finally get a chance to get it in the shop.- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
yea ill have to pull it out of the tank later when i pull the trans and transfer case sometime in October because a seal or something is leaking somewhere. and the trans has found made its self a crack in the bottom of the bell housing that I'm gonna get welded by a buddy. in the end I'm really just trying to find out what to buy to replace the pump i don't really want to pay more for the whole sending unit but well see. I do believe a junk yard near me has a zj tank that i might look into to see if its punctured and possible to replace to original mj tank with the zj one anyway this weekend I'm hoping to run Handcock pass and a few other trails with my dad so ill have some pictures of it on the trails later this week. i also ended up buying a new dash ill get a picture when i get home but i cut a bunch of bits up and made a OEM bezel fit around the ZJ cluster.- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
Hello I'm the new owner of this Comanche (not sure if I'm the 3rd or fourth owner or who knows) and i pretty sure the fuel pump is already going out on me and I'm not sure what's going on with the custom pump work. i would like to know how its set up if anyone remembers before i take it out and or i go and buy a new assembly or just a replacement pump. if i can get an answer for this i have some pictures and I'm willing to share more progress as i continue to take care of this Comanche.- 170 replies
- 5.2l v8 swap
(and 2 more)
Tagged with:
