BEEDOSAUCE
Everything posted by BEEDOSAUCE
I have!! every time I would go out I’d make sure to check if it was filled up and if not i’d refill it up. I’m just genuinely stumped because I feel as if i’ve done all the proper steps to fixing it. The only thing I can think of is if my mechanic didn’t do a good job
honestly i’m not sure, I had my mechanic provide and install it for my since it was already at the shop getting the heads repaired. how could i tell the difference?
I didn’t have a thermostat before either due to the previous owner but i had my mechanic install a new one and purge out the cooling system of any air
honestly I had all my mechanic do that stuff so i’m not sure i can answer, but the gauge on the dash board goes all the way near the second to last line whenever i go highway speeds. the clutch fan isn’t worn out much because i had it installed before and it did a great job at cooling the truck down so I'm just stumped on what it could possibly be
update, so I had changed the water pump and had the heads resurfaced because they were warped and had even installed stock clutch fan/electric fans back on the truck but it still overheats. any ideas why?? i’ve never had any overheating issues until now
wow, I think that just might be my issue. I originally added electric fans because my AC guy told me it would help with pushing in more air but after having them installed that’s when the truck started overheating
could that lead to the overheating issue?
have they been reliable so far? honestly i don’t want smth crazy just a little more power yknow
I have a guy in mexico who does custom setups but if i’m remembering correctly the fans are malibu’s
^ the truck would never overheat before either
I just serviced it not too long ago, i replaced the radiator, installed electric fans, new spark plugs, spark plug wires, distributor cap and rotor. It was working fine until this week where everything just went downhill
Sorry blew up might not be the right term, but it’s been running bad, overheating tons, burning oil, and just yesterday i started getting misfires
so my motor just blew up today a little over 300k miles, I was wondering just how reliable 4.6 strikers are and if they’re worth it? or is it worth just rebuilding the motor how it is
it’s a Laredo!!!
Diagnosing noise from engine bay
BEEDOSAUCE replied to BEEDOSAUCE's topic in MJ Tech: Modification and Repairs
sorry I should’ve specified a bit better, it doesn’t make the initial sound as it does when starting up but it sort of enhances the sound it makes while idling -
IMG_5689.mov 1988 Jeep Comanche 4.0 16. I just recently got my truck back from the painters shop and now it's making this weird sound whenever I start it up and when I accelerate. any clues on what could be causing it? my guess is the starter but i'm not too sure
factory style fog lights
ahhh that explains a lot, I installed some RC led headlights and haven’t gotten around to installing the kit so the low beams aren’t working atm. once they’re up n running the fog lights should start working correctly? -
any idea on why it’s not turning on? genuinely stumped with this, could it be a fuse that may of went out? -
Hello, i’m currently running into trouble while trying to install some factory style fog lights, i’ve already bought an OEM harness with fog lights and some HELLA fog lights but I think my issue is the switch. I got a switch from the junkyard but it was for the trans power/comfort and it doesn’t want to turn on at all. Does the switch need to be specifically for the fog lights or is something else the issue?
honestly super happy with the end results of the comanche’s paint job 🙏now all that’s left is hooking up some fog lights and she’ll be done for now
how she’s coming along!! got plenty of other stuff waiting to be added once it’s done painting such as factory style fog lights and roll bar
by any chance do you have the link for the harness kit?
- 4 replies
- fog lights
- mods
(and 1 more)
Tagged with:
I’ve been planning on adding fog lights for a while, can I just buy an OEM harness with fog lights and connect them to the fog lights/switch? or is there anything else that I would need to do
- 4 replies
- fog lights
- mods
(and 1 more)
Tagged with:
where to find comanche parts
dang alright, i’ll look around and see what works. by any chance if i were to find an OEM roll bar, what do you think would be a good price for it?- 6 replies
- parts jeep
- roll bar
(and 1 more)
Tagged with:
anyone know if there’s a legit website or where to buy things such as bed covers, roll bars, etc? I’ve looked all across facebook and even in mexico and I just can’t find anyone that’s selling parts.
- 6 replies
- parts jeep
- roll bar
(and 1 more)
Tagged with:
