Everything posted by kawaboy13
What could that be hurting? Should something feel different?
I'm not sure what that is. . . And can anyone tell me what transmission and gears i have with a 1987 4.0 standard with a dana 30 and dana 44?
Sweet! Thanks man. I've been wondering
Would this be a dana 44?
I need the seat belt buckles in tan. I will take a complete set. But I at least need the strap that screws into the floor that the belt buckles into. pm me if you've got some to ship. Thanks!
Can someone point out the LCA's?
I am tryingto get these coil springs off of a parts truck. Please help. As you can see, I have a few things disconnected. I have the frame on stands. I lowereed the jack that was holding up the front axle and it's still hanging up there. What else needs to be done? I'm trying to get these out and onto my truck before dark.
I'm mostly on road with the truck, but theres bad ruts and mud when we go hunting. I am offroad a bit also though. I'm wanting to run 31's or a little over. I have 28's on the truck. Also I want the look. My parts truck's springs are 2 inches longer than those on my truck. I figured that should accomplish 2 inches up front, because the parts truck sits higher. And the rear of the parts truck has an extra leaf spring. So free lift? How would I go about doing this? What will I need to do to change these springs out and put the leaf springs outta the other truck and onto mine? Will I need a coil compressor? Or just shock disconnect and jack it up? I kind of need some instructions. Thanks! :huh???: :dunno:
I went to hell creek suspensions. I want the 3 with springs and add a leaf I'm guessing? Also what should I add down the the bottom where thers selections?
Well I don't want to mod anything. So I guess 2 inches is really the most. Andwill i have to pull my rear axle?
I'm looking to see what the best lift kit is for an 87 Jeep Comanche 4x4. Its got the dana 30 & 35. I'm wondering what the best lift is for 2-4 inches of lift. I need an easy install also lol. I thought about a simple lift with a block for above the coil spring and i don't know about the back. I don't want to have to weld. Just want a bolt up. I don't want to mod and brake lines or anything. Thanks!
Not sure if it's had a tune-up. Its got 165K on it. It has 3.08's. It is the renix motor.Ant the tires are a couple inches taller than stock.
I feel like my 4.0 is somewhat underpowered. I see back in its day, the comanche pushed more horsepower than the other brands. But, maybe its because of the power today that I feel this way. It's a standard so it has some get up. But in 3, 4, and 5 gear, I feel like the truck is slow to accelerate. If you punch it on a new truck, it'll jump. But in the comanche, it'll just ease up. Is this normal to be able to put the pedal down and it not reall accelerate hard?
Bump
So I got all my lights to work (changed fuse) Then my brake lights blew9changed fuse) so they wrok. But now when I close my door, my b-pillar light stays on unlike before. I have no idea what to do. This is driving me crazy
What should I check for? I put 2 wires from the license plate lights together and everything went out. Help?
I cleaned it and it began to do this. I cleaned it to avoid the high idle and stick. And now it dies or idles way down when cold.
Is it normal in an 87 Comanche with the 4.0 5 speed, to idle down and almost die when you give it gas or start off after a cold start? It'll idle down when you give it gas and die if you keep on the gas. When it warms up, it seems fine? Is this just cuz its an old truck? Thanks
Where is it supposed to be back there? And what do you put the hendle on to lower the tire?
Where is the jack in an 87 comanche to change a flat? Also what'd you do to get the tire down from underneath? lol
Also I need 2 4x4 emblems and 2 comanche emblems in good shape. pm me and let me know if ya'll have anything. Thanks in advance!
Waht'd you mean?
How can you get out a taillight screw with a stripped head? Thanks!
Is this what you're talking about? http://www.prima-america.com/catalog/6072705.html
A need b-pillar lights, a tan mini console, shifter boot, and exterior window trim/channels for sides and bottom. My windows are scratched because of this! Some rubber trim should be there I'm pretty sure. :dunno:
