CheepComanche
Everything posted by CheepComanche
  1. Recently while driving I've noticed that I have to push harder on the brake pedal then I used to. Coming to complete stops, especially down hill, are very difficult. I'm assuming the brake booster has gone bad but before I replace it I just thought Id ask to see if there's anything else that could cause this.
  2. Thanks, I appreciate the insight
  3. The front end engine noise was diagnosed as the alternator and idler pullies. Does this sound reasonable and is there anything else that could possibly have been damaged like the water pump and power steering pump?
  4. Thanks, I will do that. I'm also planning on taking it into a shop to have it checked out as the sounds are getting worse and I am not very experienced. I know its probably fine, however it is my daily and I don't want to chance it.
  5. It hasn't taken long for noises to pop up. I've now got a squealing sound from the front of the engine; I think its mostly from the alternator but maybe other accessories too. And some lifter noise. Mabey my imagination but the clutch feels like its engaging later than it used too.
  6. The 2.5 and 4.0 are both non-interference engines
  7. Everything seems to be fine, I haven't noticed any weird noises.
  8. Today I was driving my Comanche when I meant to downshift from 5th to 4th but missed 4th and it went into 2nd. I quickly pushed in the clutch but the rpm still got close to 7k. It seems to not have damaged anything as it still runs fine. Is there anything I should be worried about? I have the 2.5L with an ax5.
  9. I'm currently working on installing a bass tube and I'm having trouble routing the rca lines behind the dash to the head unit. I have the wires coming up to the dash from the passenger side. The problem I'm having is that there doesn't seem to be enough space behind the dash to add any more wires going up to the head unit. Any Ideas?
  10. 1989 Jeep Comanche 2.5 / Manual / Transfercase NP207 / front D30 / rear D35 / SWB Build date: Unknown Current Location: Oregon Status: Daily driver Notes: White exterior color, Grey interior color, Bucket seats, Ax5 floor shift. Current owner: Me :)
  11. I've not been able to find any relocation brackets to finish this swap. All the relocation brackets that I've found only move the sway bar down. What I really need is one that moves the sway bar forward rather than down. I'm considering building a custom bracket or getting one built.
  12. I was looking at the Addco rear sway bar a while back and saw that it said no drilling and "bolt on" on the website. Maybe I'm missing something but I can't see how it would be a direct bolt on.
  13. Thanks for the build thread! Ideally I would like to complete the conversion with relocation brackets. I read on the Cherokee Forum that this swap could be done with relocation brackets to eliminate the drilling.
  14. I know I've already mentioned this and thanks for the the sway bar info thus far. I have a WJ bar and am seeking information on adapting that to a MJ/XJ.
  15. I already have the WJ sway bar and would like to use it as I'm not very interested in buying another sway bar. IIRC the WJ sway bar is 32mm which is nice. Its only a little bigger than stock and needs to be moved forward a few inches to clear the coils.
  16. I do see a few holes in front of the sway bar bracket. However, none of them are threaded or in the right place to mount the sway bar to.
  17. It looks like you can buy sway bar relocation mounts. Would it be possible to use those to move the WJ sway bar forward?
  18. I recently picked up a sway bar from a WJ with the intentions of it being a direct fit. After a bit of research I found that it isn't a direct fit but is very easy to mount by drilling a couples holes in the frame and moving the sway bar mounts forward. Drilling holes in the frame does not excite me and would rather not do anything irreversible. This probably isn't possible but I thought I'd give it a chance.
  19. Thanks so much for all the insight! I'll get work replacing that trans mount. In the meantime, my main focus is the center console. I know its probably nothing and it doesn't cause any problems but it does bother me and would like to resolve it if possible.
  20. I have it put back together now, but from looking at pictures its definitely a late 90s tj/yj shifter.
  21. So would the new mount resolve the issue where the shifter interferes with the center console?
  22. The transfer case is an np207. I'll get more information off the tag in a bit but here are a couple more photos I have. One facing towards the front and the other facing the rear.
  23. Where would I find the part number?
