Drained about 18 gallons of very old diesel out of the fuel tank. I purchased a little 12v diesel "mini" pump for under $25 on Amazon. Is it ok to post links to things like this or is that a discouraged practice on this forum?
I spent about 30 minutes draining the tank, the pump made it a breeze.
The fuel looked pretty bad.
I added about six gallons of fresh diesel and pumped some more until clean. Connected back up to the new lift pump and it is now running on the tank rather than my hanging fuel pot.
The PO stated that the steering box was faulty and causing issues with the hydro boost and brakes. When my son tried to drive it, the brakes didn't seem to properly release. I suspect the bad steering box was stopping power steering fluid flow and the small return line on the hydro boost was insufficient to let the pressure release.
Being lucky enough to live close by, I will be dropping by Redhead steering gears next week for an 18510 box and adding pre-porting for hydro assist. Not adding hydro in until I get the current system sorted. As I have learned from the wise, too many variable changes makes for muddy waters when trouble shooting. I will get the new box installed and then see how everything is behaving.
After much consideration, I think building a d60 front is not the wise or economical choice for getting on the road. I think salvaging this Dana 44 is the most cost-effective route for now. I will need to re-clock the inner knuckles and make some geometry adjustments to the pinion angle and how far the axle is pushed forward. The track bar and steering linkage is super close together. Not a ton of clearance for the pitman arm either.
A new set of gears, better pinion geometry, and maybe a locker and the D44 should last me just fine while I complete other portions of the build. I can do a D60 build down the road if I really feel it makes sense.
Next engine item I will attend to is topping off coolant and seeing what shape that system is in. I'd also like to start doing some wiring research. I would like to get all of the engine wiring overhauled in the bay including having all of the stock gauges working. I believe that should be doable with a reasonable amount of effort with the tach being the only one with some hurdles. The good news is it seems all the wiring harness plugs on the firewall are intact.
