Sorry if this seems long winded. I have a 1991 4.0, AW4, 2WD all stock with 65k miles on it. It’s in really good shape and has no rust…not even on the floors.
It starts and runs fine for about 15 minutes and then starts dying and coming back like you would expect a failing crank position sensor to cause. Dies for like a half second at a time, tach drops then it comes back to life getting progressively worse as the engine warms. The other gauges and lights are unaffected. Eventually it’s dying and bucking so much I have to stop. If I let it cool for 30 minutes or so I can get another 10 or 15 minutes runtime. Always starts and runs fine when cold. I think my runtime is getting less as time goes by and eventually something will fail altogether. My fuel pressure is about 34 when running.
So, anyway, I’m thinking it’s the crank sensor so I set out to get a MOPAR one….ha, not for a 1991. They can still be found for 97+ so, thinking they are most likely the same electrically, I get a 97+ MOPAR one and a new plug for my harness. I put the new one on and fire it up….within 30 seconds I have the same symptoms but with a cold engine now….WTF. Well, as the new MOPAR sensor was not U.S. made, I figured I either had a dud or the 97+ ones are not the same electrically after all. I went out and got myself a new “Standard” brand one for my specific year and made an adapter to plug into my new connector on my harness. Now I can use either type. Put my new one with the round connector for my model year on and fired it up. Same symptoms again with a cold engine. Since I was doing this work in a friend’s garage I thought, crap, I gotta get home somehow, so I threw the original, good for 15 minutes, one back on using my adapter. What do you know, it’s running good for 15 minutes at a time again. WTF. Couple of days later I get yet another two new sensors one old style and one 97+ one and they both seem bad too even when cold. The old, original one still runs good for 15 minutes. This basket full of new crank sensors I have can’t all be bad, can they?
What in the heck am I missing here? There is obviously something else bad but why does it run good with my old CPS for 15 minutes but not good at all with any of the new ones? Could there be some other piece of the puzzle that for some odd reason is more happy with my old CPS? Anyone seen anything like this?
