Everything posted by Muncher
My fuel pressure was good before hsnd but my power issue is only happening while driving so its impossible to check while driving without making some elaborate fuel pressure gauge
Ive got a 89 cherokee I'm picking up this week runs good just swapping motors for time sake. My motor either needs a timing chain or it has a intermittent stuck valve causing it too back fire like crazy randomly. Plus I lost all oil on the highway not sure i trust the motor too be good anymore.
Well new trans is in shifts great but of course the new rear main did not cooperate and blew all the oil out on the highway onto of it still not running right so new motor time!
Yeah ive tried those all always just end up making a mess.
New fuel pump and clock ring in hopefully that fixes my power loss issue. Also got the t case and transmission all bolted together ready to go in of course I forgot a pilot bearing puller so itll have to wait till tommrow.
Oil pan gasket and rear main seal done. Next is getting the flywheel re surfaced and making the newer closed system slave master cylinder work with the renix pedals. Snapchat-818441204.mp4
Mines definitely the mj XLS badge have one on my jeep wall.
Also would the driveshaft have the same output shaft as the np242?
Quick question on the np242 swap. I'm doing a 98 xj ax15 swap and need a t case there's a 98 np242 from a xj with the shift lever peice with it would that shift lever peice swap right into the mj even though its from a newer xj?
New Bosch fuel pump and lock ring/o ring which hopefully is the end to my stuttering issue basically everything electrical is new now besides the coil, ignition module and cps. Of course my slave cylinder decided to die before I could even make it run right so ordering parts for a ax15 swap tonight
Still got a terrible power surge but today I cleaned up all my wires on the c101c delete and checked the fuel injection harness jt looked fine. Re did the injector and sensor grounds and added a ground too each that goes to the map sensor bolt holes. I think my next step in solving this issue will be testing the coil and cps and possibly the ignition control module. can't wait to get rid of the 4.0 at this point.
Power stuttering contiuned...
Muncher replied to Muncher's topic in MJ Tech: Modification and Repairs
Ah ok it did thus before changing the distributor as well but I cut the old cap so I could see the rotor it was definitely at number one when I locked it downm -
What causes cross fire? -
Soon 😂 had to make sure I did it right first
Yes I did. -
What did you replace the fuel pressure regulator with? Its part of the rail kinds isn't it -
Going to check fuel pump ground tommroe all though i think I fixed it when I put new taillights in. The drivers fender ground and engine block ground were done today. -
Brand new dizzy, iac, tps, map sensor/cruiser map sensor mod and c101c delete andddd its still stuttering. It does seem the new map sensor made it worse so I'm gonna throw the old one back in tommrow. No clue what could be really causing this anyone have any ideas? and what i mean by stuttering is it will be driving along and suddenly loose alot of power kinda feel like miss firing then suddenly gain it back still drives fine and does not brake down or anything but I hate driving it like that. Could the cps cause this? Its basically the only sensors I haven't changed
I tried too used a pair of the needle probes on the multi meter but couldn't get a good reading on it i had it hit 82 on the meter so I shut the truck off ame tighten it down there.
New tps installed finally seems too not really sputtering now but it might have done it once earlier while driving weird issue might have to do a dizzy
Did you fully delete your egr?
Its just a dorman catch can from autozone or any local parts store kr was expensive but thats the price I pay when I'm impatient and hate ordering online lol. Of course I deleted the ballast resistor and used that spot to bolt it up and bent the bracket around the body right there. Also moved the egr thing over to the ground off the harness
Yeah weird that it just does not work at all anymore I don't wanna put the old one back in cause it does not work right and that little hole pours coolant out like no kther
